Starcraft Enterprise
- Aug 18, 2009
- 246
Abc
Ok, thanks for the good info and advice. Does the III also have the odd ball transom pattern as far as converting to a newer style outdrive?
I did remeber a few of these old monsters coming into work on when no one else would even want to even winterize them They did shift from inside the boat with some sort of in and out box for foward and reverse . The also had an automotive type clutch bolted on the flywheel . For nuetral they had a 12 volt starter motor rigged up to a lever arrangment that would push in the clutch release fork so you could shift in a normal fashion like they are today It was an engineering nightmareThere is an estate auction this saturday with a 23' 1969 Thunderbird Iroquois in really nice original condition. I went and checked it out today, has a small block Chevrolet V8 engine and a monster size outdrive on the back. Came home to look it up and determined it is a Mercruiser Model 2. I am completely ignorant on these outdrives, did not even realize Mercruiser made any other outdrive in 69 besides the MC-1. It appears to be a low hour original, in like new condition. This boat must have spent most of it's life in a barn. Are these outdrives any good? Should I run away from it? Parts availability?
