Hey guys, on the Mercruiser 4.3LX IVThunderbolt the wiring diagram say that the purple w/yellow strip wire that runs from both the fuel pump and the oil pressure switch runs to the starboard post on the starter (opposite the solenoid post). On this starter, there is no 3rd post, only the main and solenoid. Currently the said purple/y wire is just not connected, but the re is a wire there and definitely looks to be apart of the original harness. What do I do?
The motor isn't starting, the pump does however power on while cranking (seems sporadic though), it acts as though it's starving for fuel even when it did run. Also, the audio alert system was disconnected I noticed....I have it reconnected how it should be now.
I need guidance please.View attachment 118912
