Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Bypass kill switch?
  • Bypass kill switch?
    How do you bypass the kill switch 87 Mercruiser 3.0 litre 140 horse?Have new coil, alternator, starter, plugs, dist cap, carb, fuel pump.How direct wire from ignition to starter solenoid? From Tach?My wire colors don't match the Seloc repair manual for Mercruiser Stern drives.I have purple, tan, grey not on the wiring harness they show
    Re: Bypass kill switch?
    Disconnect the wires from the switch and hook them together.All the switch does is stops power to the ignition. By spicing the wires together, you bypass the switch completely.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      is there a reason that bypassing the kill switch would be a bad idea other than maybe the obvious safty issues - thinking i may be having trouble with mine
      • #4
        • #5
          i would only do it long enough to decide its bad and then put it back correctlytommays
          If a dirty bottom slows you down what do think it does to your BOAT
          1970 Cal 29 Sea Fever
          http://cal29seafever.blogspot.com/
          1981 J24 Tangent 2930
          http://s565.photobucket.com/albums/s...%20for%20sale/
          Tommays
          Northport Ny
          • #6
            I agree with tom, only do it to confirm what you think is bad and replace if needed. It is a safety thing, but my boat doen't even have one.
