Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
timing 4.3 with thunderbolt ignition
  • timing 4.3 with thunderbolt ignition
    I had to change intake manifolds and now i have to check the timing. Can I simply check the timing at idle or are there different procedures with this ignition. Thanks
    Re: timing 4.3 with thunderbolt ignition
    If it's the thunderbolt 4 ignition, you have to bypass the computer advance by grounding the purple wire lead at the distributor. Set timing and don't forget to take the grounding wire off.
    Sometimes it's more important to be human, than to have good taste. ~Brecht
    • #3
      Ayuh,... With T-Bolt IV, ya just hook up the timing light, 'n shoot....
      T-Bolt V needs the jumper wire to set it to base mode, then time it...
      • #4
        I stand corrected. It,s the ignition amplifier that supplies advance on the 4. The 5 is grounded for base timing. I was confused for a second ,Thanks Bond-o
        • #5
          Thanks for the quick response. I have the TB 5 ignition but it doesn,t have a purple wire on the distributor it ha s a black going to ground and 1 white with red stripe and 1 white with green stripe The only purple wire is from the coil. what do i jump and how.
          Thanks again
          • #6
            It's not on the distributor, look up next to the carb on the starboard side. Why is it newbies never seem to think that a simple think like the year has any impact on their engine? All 4.3's are not created equal.
            Click image for larger version
            Don S.
            Please, no PM's (Private Messages) regarding boat/engine problems.
            That is what the forums are for.
            Only forum/moderator issues will be answered in PM's.
            • #7
              I dont have this ignition, mine is IV, but... Manual says for V there is a purple and white wire in the harness, with a spade conector, between the ICM and KCM. Run to engine ground with jumper and this makes it run on base timing. Start and use timing light as usual.
              Note: it also states that the carb shoud be adjusted with the engine runing on base like this as well.
              • #8
                Thanks for the info I will try that in the morning
                • #9
                  [ATTACH=CONFIG]117005[/ATTACH]
                  thanks for the info. sorry for being a newbie
                  • #10
                    When I checked the timing when I grounded the purple and white wire and set it at 10 deg as it says to on the top of the carb. when I unhooked the wire and checked the timing again it was still at 10 deg. Is this correct or should it have changed. Also it idles just fine but when it gets to about 1900 rpm it starts to run bad and backfires sometimes. What else could be wrong and what should I check next. I also checked the pos side of the coil with the key on and it has the same voltage as the battery. Thanks
                    • #11
                      Did you set it into timing mode and take it out of timing mode at the right time?
                      Did you read and follow the procedure I posted earlier?
                      Don S.
                      • #12
                        I read the instructions and the only thing i couldn't figure out is where it says to remove jumper wire from timing terminal. Is that the same as the purple and white wire for the ground if it's not the instructions never say hook up any jumper wire from the timing terminal. If it's a seperate step to do can you please explain. The engine is a 2003. Thanks
                        • #13
                          Read item 8, especially the bold part that says important.
                          Don S.
                          • #14
                            I read #8. I'm talking about #7
                            • #15
                              Step 8 seems to restate what the second part of step 7 says. And then again puts it in Bold
                              Does the timing move as rpm comes up?
                              Why was this torn apart to begin with?
