Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Mercruiser 260, No Spark- Thunderbolt IV
  • Mercruiser 260, No Spark- Thunderbolt IV
    Hello,I'm getting no spark in a Mid 80's Merc. I've replaced the distributor module, rotor, cap, & coil. The only thing I believe that is left, is the Thunderbot IV ignition module. To test (the only way I could think of) I pushed 14 volts through the module from a jump box and I'm getting 7 out the other side. Is that normal or is there something else I should be looking at to fix? Any help would be sincerely appreciated, I'm dry docked and just missed a great weekend.Thank you!
    Re: Mercruiser 260, No Spark- Thunderbolt IV
    That is a test I have never done. If you are getting +12V to one side of the coil, and a pulsing negative (as you turn over the engine) to the other side of the coil you should be getting spark. As far as I know, the ignition module deals with the negative side of the coil. You are going to need at least a DVM to troubleshoot this problem. I would start by looking for +12V on the positive side of the coil (that would be a key switch,wiring problem if not there).
    • #3
      Check out the flow chart.... web page
      • #4
        Thank you! Have you ever heard of a shift cutoff switch? I'm being told that may be the actual problem. I have run through the flowchart and ended up at the "replace ignition module". However the chart does not mention the shift cutoff switch.
        • #5
          The cutoff switch you have heard about, momentarily kills the motor to allow you to easily shift from forward to neutral and same for reverse. When they are working right you don't even notice it happening.
          • #6
            Hopefully my last question.Would it be possible to get NO spark if this switch has gone bad? Can I permanently bypass the switch?Thanks again
            • #7
              Yes, that's what it does: interrupt the spark while shifting. No, don't bypass it, doing that will only make your gears grind and lead to eventual failure in your drive.
              Disclaimer!: In my inexpert opinion......
