Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Alpha gen 2 shift adjustment
  • Alpha gen 2 shift adjustment
    After putting lower unit on my boat I thought I'd go ahead and adjust the shift cable to make sure it was set correctly. I have a selco(?) manual that is fairly vague about this process. Can anyone provide a better explanation? I'm most concerned about the consequences of too little or much travel. Too little seems obvious but what about too much?
    Re: Alpha gen 2 shift adjustment
    http://www.boatfix.com/merc/Servmanl/14/14a2.pdf around page 14 will give you the right stufftommays
    If a dirty bottom slows you down what do think it does to your BOAT
    1970 Cal 29 Sea Fever
    http://cal29seafever.blogspot.com/
    1981 J24 Tangent 2930
    http://s565.photobucket.com/albums/s...%20for%20sale/
    Tommays
    Northport Ny
    • #3
      Here's a link to the Mercruiser service manual, it's not vague at all. See section 4 starting on page 28. http://www.boatfix.com/merc/Servmanl/14/14cover.pdf
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Man that service manual is nice. Is there a link I can access to give me an index?Thanks again guys!
        • #5
          Alright, I hate my boat. I just spent about 3 hours trying to adjust my shift cable per instructions and it is not making me happy.When I put it in reverse it clicks heavily in couterclockwise direction then catches in the other. In forward it clicks very very lightly in clockwise direction but will catch in the other.Assuming the springs are the same load on the clutch in forward and reverse, why can I not equal out the clicking? When I try to make the forward clicking equal the back then the back just clicks in both directions. I would be much happier if it were the sounds were the other way around as I spend much more time in forward and want to feel comfortable that I'm getting postive contact.
          • #6
            From this link, http://www.boatfix.com/merc/Servmanl/14/14cover.pdf Click in the red box that says "Sterndrive units, Alpha I Generation II"From there scroll down to the index on 4.Now, to your problem. Sounds to me like one of your cables has a lot of excess slop in it. Probably due to wear. The outer sheath of the cable gets worn and the inner cable that does all the pushing and pulling just has more places to go so there isn't the total movement needed anymore.It could be the engine to drive cable, or it could be the engine to shifter control cable.You shouldn't have more than "Maybe, about, Uh, not sure" 1/4" slop in the forward cable, and a lot less in the engine to drive cable..
            Don S.
            Back to Top
