Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
5.7 ltr mercruiser. Fuel wont stop squirting from over flow hose going to carb?
  • 5.7 ltr mercruiser. Fuel wont stop squirting from over flow hose going to carb?
    Pulled off over flow hose that burns access fuel in carburator. When motor runs it constintly squirts fuel into carb making engine run bad. Pulled hose off and motor runs great. What would make gas come out of there at a steady flow? Changed water seperater thought maybe it was clogged but still did it.
    Re: 5.7 ltr mercruiser. Fuel wont stop squirting from over flow hose going to carb?
    Your fuel pump is Junk, replace it.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      hmmm. Is there a batter in there that went bad?
      • #4
        Look and you will see the other end of that hose goes to the fuel pump. If the pump develops an internal leak it dumps the leaking fuel into the carb instead of in the bilge. Replace the pump and be sure to use a marine type. There are several aftermarket ones so you don't necessarily have to buy one from mercury. I believe even Napa carries them. MARINE ONLY!
        sigpic
        23' Nordic Viking
        500HP BB Chevy
        TRS Drive
        • #5
          Ayuh,.... What'd ya do with the hose,..??
          Was it still squirtin' gas,..??
          • #6
            I was out 12 miles in the gulf. It had a clear tube running to the carb and i saw gas running through it so i pulled it off and stuck a screw driver in it and left the hatch open and idiled back in and killed the rest of my 12 pack lol ****ty day had some hot girls out with me to.
            Back to Top
