I have a 1984 Volvo 200D with both an ammeter and voltmeter on the dash.Everything seems to be charging o.k.with 13.2 to 14 volts, depending on RPM,on both the voltmeter and on the multi-tester on the battery terminals.However the ammeter is always reading on the negative side,and when I turn on any accecories it dips even lower.What does this mean and whats the difference between a voltmeter and an ammeter? Do I just have a faulty meter and if so how do I check? I have 2 new, high quality batteries. Thanks for any info.
