Re: Digital Water/Engine temp Gauge....
We dumped it in a lake this evening, to get it off the hose. The temps had been spiking up to 240 on the hose and jumped right back to 230-240 after just a couple of minutes in the lake. I'm not sure what you mean about fresh water cooled except to enquire if it uses outside water. It does. We think that either the thermostat is stuck or we put the lower unit on in such a way as to prevent the water coupler from installing properly. <br /><br />This mess was precipitated by ingesting weeds in a lake Toho near Orlando. It overheated and got pretty hot for a few minutes and the boat idled back to the dock. At idle it seemed to drop to about 180. Any throttle resulted in 230 up. We put in a new impeller, although the original looked quite good except for a small amount of "set" to it. The coupling tube that connects the water pump assembly to the upper unit was melted down pretty badly. Replaced that as well.
