Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Distributor cap corrosion
  • Distributor cap corrosion
    Sensor test dosnt work by the book.Unplug the two sensor wires from the sensor ,and anything less than 100 ohms between the two sensor leads and the sensor needs replacement. All i got was range error on the multimeter ,tried differant ranges but no results.This all came about when i was out 10 miles on the ocean and the motor just died twice in a row .I got it running and got back to the dock .I checked the kill switch lead .Tried wiggling wires while running (nothing).Then my service manuall had this sensor test,but it didn't work. 2001 5.7 carburated mercruiser.
    My distributor cap has green corrosion on all terminals.Can you clean them with fine sand paper or replace cap? Would this cause intermittant engine stall that i had last time i was on the ocean? 2001 mercruiser 5.7 carburated. Much appreciated.
    • #3
      Re: Distributor cap corrosion
      Cap, rotor, and spark plugs are maintenance items called a tuneup. REPLACE them, and yes they will cause your miss.
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Re: Mercruiser distributer sensor 100 ohm test
        Donno what it might be, but I've never heard of that module stoppin' 'n restartin' to work...
        When it dies, it's Dead...
        I merged yer threads,...
        No reason for several threads about yer No Run issue...
        Please keep things together, to lower the Confusion factor...
        • #5
          Thanks for the response,its wasn't a miss,it just died.
          Back to Top
