Drewmeister
- Sep 2, 2011
- 53
OK, so I have removed the bell housing and all of the old bellows and dry rotted water xfer tube on my Alpha 1. I am learning that hose clamp placement and orientation is KEY in doing this job, I bet I have spent an hour total just figuring out how to orient the clamps for ease of tightening later! Following the Merc manual, I have the following back in place -
1. Water xfer tube. Boy that is a b*tch to get back on the transom side!! I hope I have if far enough on. It is connected to the bell housing as well.
2. Exhaust bellows connected to the gimbal housing (i.e. transom side).
3. U-joint bellows connected to the bell housing.
4. Shift cable bellows on the cable and partially crimped on the narrow end.
5. All hose clamps oriented for ease of tightening (I think) and I have a flexible socket.
I DO NOT have a bellows tool as the Merc manual suggests, but have other tools I think will work.
SO, my question now for those who have done this job one or multiple times...any hints on getting this all back together? My plan of attack was to connect the U- joint bellows first and tighten, then pull the exhaust bellows on and tighten then connect the shift cable bellows and tighten. Any thoughts? It's gonna be real tight work of course!!
Drew...
Drew...
