Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone elses topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when its posted at the end of someone elses topic. And those answers will be specific to your particular issue.
See more
See less
Timing marks 1996 Mercruiser 5.7
  • Timing marks 1996 Mercruiser 5.7
    I am trying to time my 1996 Mercruiser 5.7 and am having a hard time understanding the timing markson this engine. Can some one advise? I know that 8degrees BTDS is correct. I just can't read the timing marks Thanks
    Re: Timing marks 1996 Mercruiser 5.7
    Below is a drawing of how the timing marks are setup. Do you know if you have a Thunderbolt IV or Thunderbolt V ignitions system. The method of timing is different for the TBV ignition from the standard TB IV ignition.
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      I have a Thunderbolt IV. My timing marks do not look like that though. On the cover it almost looks like a U with no marks but a line in the middle. If I had to guess I would say the line is TDC and the U points mark 8 degrees before and after if this makes any sense to you.Thanks
      • #4
        Merc puts a lot of paint on them, and sometimes you can't see any numbers.The deepest notch is always 0° or TDCThe high peaks (Points toward belt) are 4° apartCan you post a picture of your setup if it's different?
        Don S.
        • #5
          Thanks Don,I will try to take a digital image of the time marks tomorrow. Is there any trick to attaching an image to response?
          • #6
            Look at this thread for instructions given by Dunruna, if that doesn't work for you, let me know and you can email the picture to me. http://www.iboats.com/cgi-bin/ubb/ul...;f=24;t=011127
            Don S.
            • #7
              Hello Don,Lets see if this image comes through. [IMG]
              • #8
                Don, Please send me your e-mail so I can forward image to you.my e-mail is:keastman@socal.rr.com
                • #9
                  You got mail.
                  Don S.
                  • #10
                    While all the information I posted earlier about your timing marks is correct for a 96, 5.7L engine. HOWEVER, you seem to have a 2001 or newer engine in your boat.That "plastic" timing chain cover is only used on the newer blocks and can not be used on older ones. So obviously you have a newer engine than you thought. But back to the timing.There is a notch in your vibration dampner that is at 0° or TDC. What you need is a decal to put on the vibration dampner. Mercruiser has one, and the part number is 37-864360.If I was you, I would order a couple of them so you have one on hand, that or when you put it on, scribe a mark in the vibration dampner and mark it so it can't go away. Use the decal to locate the proper mark for your engine.Just be carefull and put the decal the proper direction. See my earlier drawing. Your photo for others to see (smaller of course)
                    Don S.
                    • #11
                      Thank you Don, for your research and your help. I bought the boat used and did not know that there was anewer engine.Thanks
                      • #12
                        Don,How could I confirm the newer block besides the timing cover, would the serial number on the block identify? I am interested because I know I have the pre votec heads so possibly some one put a short block, which might then have the newer hardened rods and pistons which might make it more practical to consider putting on the vortec heads and converting to a 4 barrel carb in place of the 2 barrel.What do you think?
                        • #13
                          Don S.
                          • #14
                            I believe the plastic/composite timing cover started in '97, on all sbc's, not just vortec. A slightly changed water pump to clear the new cover, too. Also thought Thunderbolt V started in '95. If the block has been replaced, short of a teardown, you can't tell what was done or what parts are in there.
                            • #15
                              I thought it did to, but look at the drawings from the parts books below. Not sure what engine he has, but the 97 service manual shows the metal timing mark, so that is what I gave him a picture of. When he sent me the photo, I only found it in the manual for the 2001 and newer engine. Understand now that I was looking for timing information, not front cover composition.Here is what I found when I went looking for the composite front cover in the parts book.99 to 2001 was this one, with no pictures of the timing mark in the 98 to 2001 service manual. Then in the 2001 parts manual I found this picture, and the 2001 and newer manual showed the decal and composite cover on the engine that I posted. I also found this in the 98 to 01 service manual Thus I gave him that information. I have now looked some more and it looks like the composite cover was used from 98 and up, but the metal cover was also used.Strange to say the least.
                              Don S.
