Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Oil coming out of the dipstick tube
  • Oil coming out of the dipstick tube
    I have a 4.3L V6 merc and I am getting oil out of the dipstick tube. I have 160 to 170 compresion on all cylinders. There is no water in the oil. Any ideas?
    Re: Oil coming out of the dipstick tube
    Put the dipstick back in!
    • #3
      Your PVC valve is plugged up.
      • #4
        PCV....
        Positive
        Crankcase
        Ventilation
        Sorry, i just had to do that..
        • #5
          As previously posted....PCV valve. Pull the valve off and holding it by each open end, shake it lightly back and forth. If you can not hear the metal ball rattling back and forth, change it out.
          Another thing that would cause this is if the engine was FULL. I mean full of oil; oil and fuel or oil and water. You already stated there was no water....................
          Is the oil very black and does it smell like fuel?
          • #6
            I like that smart *** comment the best.
            • #7
              cracked dipstick tube
              overfilled and aerated the oil, check and adjust oil level
              excessive blow-by , check with leakdown test
              you dont list a year, may not have a real pvc valve, just open tubes going to the flame arrestor.
              NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
              • #8
                Are you sure it has PCV's. Boat generally do not have them.
                • #9
                  The boat is a 2006 with less than 100 hours on the motor. The pcv valve is just a tube. The oil is black and does not smell like gas. I did put the dipstick back in tight and it still leaks out the top of the tube. It only does it when the boat is ran at high rpms. It does need an oil change but I would think that would not be the problem.
