Ok, five bucks to the first person to solve this mystery.
The boat is an 18' 1968 Fiberform Continental with a Mercruiser 120 I/O, fuel tank in the bow. When I take off from the dock, I can run WOT for about 5-10 minutes, then the engine dies from fuel starvation. Eventually I figured out that when I disconnect the fuel line from the fuel pump on the supply side, there is a loud PSSSHH and then fuel flows again. From there on out it's progressive... I can go less and less distance between the purgings.
At first I thought I had venting issues in with the tank and a vapor lock was occurring, but the problem persists with the fuel cap removed altogether. Then I thought maybe it was the water separator/ filter and bypassed it. Then I thought maybe it was old fuel line collapsing under pressure and replaced the line. Finally I gave in and bought a new fuel pump (not really sure how it could be the problem)... but the problem is still there.
So my question is this: How does air get in the fuel line at all if it goes straight from the pickup at the bottom of the tank, into the fuel line, and to the pump? Would a crack in the pickup tube do this? It seems to me that if air was getting sucked in along with the fuel it would get progressive, as the pump would be having to suck on all that air stacked up in from of the fuel... or maybe not. I'm running out of ideas, and I really just want to go fast in my boat for more than 10 minutes.
Help, anyone?
Help, anyone?
