89cruisers
- Jul 11, 2005
- 190
I'm curious as to using permatex exhaust manifold gasket maker for the exhaust riser, would I still need to use that steel plate? or just put the gasket maker down and then throw the riser on? Ive used it before with exhaust manifolds on cars without any problems, but what your advice before using it with a marine application. What is the purpose of having a steel plate sandwiched between two gaskets anyways? Also, the couplers for the exhaust rise to the Y-piper are a good $50, is there any harm in using exhaust hose?
