Rellik546
- Feb 5, 2011
- 270
Where exactly do you hook up a vacuum gauge to check cylinders, and also to adjust idle mixture? I know its suppose to be hooked up to the manifold, but where? is there a barb it can hook up to? i cant seem to find any info on where specifically to attach the gauge in the manual, it just says attach to manifold. the manifold is directly under the carb, but i cant seem to find anything to attach it to. i have a 85' mercruiser 140 181 with a rochester 2 barrel carb. also if testing my fuel pump, it test the line between the pump and carb which is a steel tube. so i just get 2 thread to barb connectors and a tee fitting. thread appropriate sized threaded barb adapters to threaded connections, then attach tee fitting to vacuum/fuel pressure gauge. and use spare gas line pieces and attach to the barbs on the tee fitting and then to each of the threaded barb fittings i just installed. is this the proper way?
