Here goes my first post! I have a 1986 Crestliner 25' Cuddy, with a Merc. 260 H.P. Chevy 350 I/O with a Gen II outdrive (Low hours on the whole outfit!!). I am cosidering upgrading from the stock 4 bbl carb., to a TBI (Throttle Body Injection) or a MPI (Multi-Port Injection) fuel delivery system. I am planning on robbing the system( along with the ECM) from a wrecked vehicle. This may sound odd, but I want to keep my boat and improve upon the exhisting Carbed system. The headache of the carb., not to mention performance gains, are my main reasons for wanting to perform this swap. Has anyone heard of or have yourself performed this modification? I am aware of some of the actual mods that need to be made (for MPI...my first choice). I know that I will need to install a high-output electric fuel pump with return as well as an oxygen sensor (I also thought I might be able to use a closed loop system). An upgrade in the distibutor is necessary to allow the computer to advance or retard the timing. I was planning on getting this from the donor vehicle. The wiring for the ECM would be relatively simple... positive, negative, O2 sensor, fuel pump and distributor. To my knowledge, pre '97 (non-vortec)Chevy heads and blocks are all the same, and I assumed this would apply to marine engines as well. The TBI option is not my first choice, but any input on it , too, would be appreciated. Does anyone with a newer boat have MPI or TBI on it?
