Re: Correct timing for 1999 Mercruiser 3.0L with EST
12. With timing light still connected, start the engine and run at IDLE. Verify that timing did
advance to :
? If initial timing is 1? BTDC: 12? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
(total) advance is obtained and should be 23? BTDC (plus or minus 2?).
? If initial timing is 1? ATDC: 14? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
(total) advance is obtained and should be 25? BTDC (plus or minus 2?).
? If initial timing is 2? ATDC: 15? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
(total) advance is obtained and should be 26? BTDC (plus or minus 2?).
It indicates that by retarding my timing (ATDC) that I'm actually getting more total advance 25* vs 23*. I don't know how that works since they all use the same module unless it is something different in the distributor itself.
I thought the same thing when I read the manual.
How does retarding initial timing give you more total advance? That didn't make sense to me either, unless for some odd reason the EST does that. I was going to check it out the next time I was timing the engine, see if retarding the dizzy gives more total advance. Also, If the engine is blowing head gaskets,
WHY would you want to give it MORE total timing, that makes no sense at all? (I have a feeling the manual might be wrong as this doesn't make any sense to me.)
What would make sense to me is....... (I changed the numbers)
? If
? If
initial timing is 1? ATDC: 10? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
21? BTDC (plus or minus 2?).
? If
initial timing is 2? ATDC: 9? BTDC, plus or minus 2?. At 2400-2800 rpm maximum
20? BTDC (plus or minus 2?).
