Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Help my boat is sinking. It is taking on water
  • Help my boat is sinking. It is taking on water
    I have a 1976 25 ft sea ray with a pre alpha mercruiser I bought it after sitting 10 years. I replaced the bellows and shift cable. When I put it in the water I am taking ona lot of water from the ujoint bellows area. From what I can see itís coming from the ujoint bellows area but is hard to see. Is there anywhere else the water could be coming from besides the bellows? It does not take on water when running on muffs.
    Thank you
    Re: Help my boat is sinking. It is taking on water
    It could take on water from a million places......Did you use adhesive on the bellows? Dunno if your supposed to on the pre alphas or not....
    'Dehydrated'
    sigpic
    93' Nova 202 Spyder 350 Mag
    • #3
      I did put sealer on the bellows. they seem tight where they are.
      thank you
      • #4
        thank you
        What kind of sealer did you use?
        Boating from Midland Ontario on Georgian Bay, the best fresh water boating in the world!
        2003 Cruisers 4270 with Crusader HO 8.1 engines
        • #5
          Put water in the bilge when it is on the trailer and see where it comes out.
          83 Sunrunner 16.5 120 merc Alpha 1 drive SOLD 8/1/13
          1996 Crownline 202BR
          5.7l EFI 0f791070
          Bravo I drive
          GMC Yukon tow rig
          • #6
            I used clear silicone as a sealer is that bad ?
            • #7
              This sounds like a rotted transom. Just back it in the water leave it on the trailer. Then get back there and see where its coming from. Use a flashlight and mirror to help you look around. Goodluck.
              1990 Stingray 536ZPX 4.3 Mercruiser - SOLD
              2001 Glastron GX185 4.3 Mercruiser - SOLD
              2012 Yamaha SX190 1.8L Jet Boat
              Tow rig - 2013 Silverado 2500HD Duramax
              • #8
                it's not good. silicone is not the specified adhesive, just did mine on an mc-1 ("pre-alpha").
                Monte
                1979 19.5' GlasPly Cuddy Hardtop (floor, foam, transom gutted)
                Mercruiser 470 (sitting on a stand on the floor)
                • #9
                  Another possibility is the shift cable bellows. If this isn't right or tight it can sink a boat fast.
                  • #10
                    Take a look at the photo by Fishermark attached:
                    You can see right into the bellows? How bout that large gasket that's between the drive and bellhousing? If water leaks by it guess where it is going?
                    • #11
                      are you talking about the gasket you can see in the pohot?I was wondering about that one I had some problems getting the out drive on when ii changed the bellows
                      • #12
                        Yes, its bad. You should be using bellows adhesive. It appears that you are very inexperienced working on boats. My suggestion would be to take it to a shop and let an expert do the work for you.
                        • #13
                          If he were experienced, he wouldnt need to post in the forums. He has replaced the bellows and shift cables already which tells me he has the basic skills. Why would you suggest he let an expert do it? I thought the whole purpose of this forum was to provide help and advice to those of us that have the desire to be able to work on our own boats without the need to pay an "expert" to do our repairs.
                          Todd 22' STARCRAFT SS V5 200hp
                          • #14
                            Thanks for the support. It doesnt bother me when people make statments like that it tells me they think they know all but they dont. He doesnt know me I spent 20 years as a heavey equipment machianic. I have rebuilt everything from V16 Cat motors to chain saws. There are more than 1 way do to do things and get the same results. remember an open mind is a shut mouth. Thanks for the help guys
                            • #15
                              I have to concur on the bellows adhesive. Although I use a contact cement. The silicon RTV turns into a lubricant after it has been in the water a while. The bellows is hard to see when you are putting those clamps on (especially the aft), and it is possible to overtighten and pull the seal down. You can check by pulling the drive and running your hand along the seal.
                              I'm doing a transom bellows reseal job myself this week. Just got it apart today, and odered the parts from iboats here.
                              --Jim
