I had a bad voltage regulator (water cooled) on my 1984 merc 470. Also had a burnt fuse link that is mounted off of the starter selinoid. I am replacing both parts. I have some doubts about the wiring to the fused link on the starter selinoid. The fuse is mounted to the large post on the selinoid. It has two large red wires mounted under it. One is a positive battery lead and I think the other wire goes to a bundle of wires in the harness. The other end of this fuse link has a small wiring post. This post had one tan wire on it that goes to the voltage regulator. As far as I can see this fuse is only protecting the wire to the voltage regulator. My question is: is this wired correct? Or are the wires in the wrong place? The starter was replaced years back and the wires may have gotten in the wrong place. If anyone has a 470 with this set up that can look at it and tell me where the wires go on this starter selinoid fuse link. Thanks.
