Mercruiser Riser elbow gasket question
othelloears
I am replacing the manifolds and risers/elbows on my 1984 Mercruiser 228 and can't figure out which gaskets to use between the manifolds and riser.
They sell 3 different. (4 hole, 2 hole and no holes/blocked)
Mine is full raw water cooled so i assumed I need the one with 4 open slots. The one with 2 open slots seems to be the most common.
Please help
Thanks
Don S
Re: Mercruiser Riser elbow gasket question
Have a look at this Merc Service bulletin, it explains which gaskets to use.
  • SB 99-10.pdf
04fxdwgi
Please help
Thanks
The correct ones for my 7.4 w/ raw water cooling are the 2 slot ones w/ 2 small holes. Slots go on side to side with the 2 little holes facing fore and aft.
The 4 slot ones are used when riser blocks are used between manifold and riser elbow. They are to go between the riser block and riser elbow, with the 2 slot ones between the riser block and manifold.
The no holes ones are used when you have fresh water cooling (and should be used with the S/S block off plates for strength) and go between the risers and manifolds to isolate the raw water from the engine coolant.
othelloears
You guys are great thanks
I have to lok at the boat but in think I need the restrictor 2 slot because I have the connection frm the riser to the termostat.
Do the slots go fore and aft or the big slots?
04fxdwgi
