So I noticed that at least one of the bellows needs to be replaced. If that's the case, might as well change them all! And the main drive bearing while I'm at it.
Can anyone give me some pointers as to what I need to do? It appears I will need to drop the outboard, never done this before. Or if someone has an easier method..
From what I saw on youtube it seems like you just take off the prop, pull the pin holding the rams, unbolt the six bolts at the top of the out drive, give it a good hard jolt then VOILA!
If only things could be this easy...
