Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
How do you tell the difference between a 350 and a 454?
  • How do you tell the difference between a 350 and a 454?
    Story: Step-Dad is looking to replace carbs due to one is Edelbrock (non-marine) and one is Rochester Quadrajet Ser# 17059293 (for a 350).
    He is not sure whether the engines are 454 or 350.
    HE says the serial numbers are 28526 and 27699 (which doesn't look right from the numbers i see on sterndrive.info.
    So, where would the serial numbers be so i can look up the block, or.. how can you visibly tell the difference between a 454 and a 350?
    Boat: 1979 Uniflight 36ft Sport Sedan.
    Ben Meyer
    1988 Sea Ray Seville 200
    Re: How do you tell the difference between a 350 and a 454?
    Small block and big blocks where Chevy is concerned are so named because of the physical sizes are so different. The Chevy small blocks generally ran from the early 265 cid all the way up to the 400 cid engine. The big blocks ran from a 396 version all the way up to the 454. Now a 396 may displace less than a 400 but put them side by side and you will NOT mistake one for the other. The 396 is a larger engine with respect to external dimensions. Size of the valve covers between the two, the 396 is much larger.
    Spark, Air and Fuel... all you need.... well, and beer!
    • #3
      BBC has flatter, wider looking valve covers.
      Look at the side of the engine, and the exhaust to spark plug orientation.
      SBC: exhaust/sparkplug/sparkplug/exhaust/exhaust/sparkplug/sparkplug/exhaust
      BBC: exhaust/spark/exhaust/spark/exhaust/spark/exhaust/spark
      1990 Wellcraft eclipse 216
      Mercruiser 5.7L Alpha 1 1.47Ratio 14.25x19" 4 blade aluminum prop
      2002 Ford Explorer XLS Tow Vehicle
      2010 Chevy Camaro RS/SS Daily Driver
      • #4
        ^This. The easiest way is by looking at the exhaust manifolds for the exhuast port pattern. If the exhaust ports are evenly spaced it's a BBC, if they middle two ports are closer together than the outer two ports, it's an SBC.
        1976 Mark Twain 200VBR w/Mercruiser 233 (Ford 351w) "Heart & Soul"
        • #5
          And the carbs will not care which you have.
          • #6
            not sure what you mean here..
            however, the manuel says the engine is a ch350rh, 350HP year 1979, and it says 454cid, so i tend to think for sure they are 454s....
            Ben Meyer
            • #7
              I mean the carb will fit either engine.
              • #8
                Ayuh,... Then you'll need a pair of Edlebrock 750s....
                The SBC's usually prefer the 600 copies...
                The Edlebrock performer series is a Carbon Copy of the Merc/ Weber carbs still in production...
                But a 'ell of alot Cheaper, 'n easier to get tuning parts for...
                The Edlebrock kits work Perfectly in my Merc/ Webers...
                • #9
                  Post a picture of your engines. Many here can tell the difference with just a quick glance.
                  If they are Mercruiser, and I would guess they are MIE (inboards) and not IO's, there should be a metal tag just above and slightly aft of the starter.
                  Don S.
                  Please, no PM's (Private Messages) regarding boat/engine problems.
                  That is what the forums are for.
                  Only forum/moderator issues will be answered in PM's.
                  Back to Top
