DoctorThunder
- Nov 10, 2004
- 11
Just picked up a 1990 22ft. walkaround Avalon, made by Raven Boat Co. It has a 3.7LX Mercruiser with a closed cooling system...I changed the oil and filter, no problem....Cannot get to the plugs for the freshwater,sea water or engine block. Am I the only one having this problem? Engine is packed in super tight especially with the heat exchanger...Decided to suck out the antifreeze from the top holding resevour, drain the hoses and drain as much as possible from the heat exchanger with my new handy dandy hand pump ...Put in new 50/50 antifreeze....added fuel conditioner to tank....warmed up engine 5-8 min. with water from the garden hose, shut engine off....hooked up the ol' 5 Gallon bucket full of antifreeze mix...the juice was definately getting sucked in the out drive but didn't seem like hardly any was coming out....ran it for 5-6min....then decided to fog the engine.....ran for a min. or two saw the white smoke from the exhaust and shut down....Did the engine get enough antifreeze from the 5 Gal. bucket? Did I run the engine long enough? Why wasn't antifreeze pouring out of the exhaust? I have a great manual.....when I look at the engine, I just shake my head and think "How can anyone get in there to work on this thing?"
