Hi,<br /><br />While I am waiting for my Seloc manual to arrive. Would anyone be willing to look up the specs for my 1964 MErcruiser 110 hp? All I need is spark gap, point setting, timing @ what rev?<br /><br />Many thanks!<br /> Ethan
plugs .035--pts. .016 or dwell 39 to 45 degrees timing 8 degrees at 800 rpm with mid grade gas. Run some product thru the engine before adj. the valves that may stop the noise. [ATF?] if that don't work the adjustment is 1 turn down from slack, I set most at 3/4 --bob
