Frozen Shift Cable
Joe Dillon
Purchased this 1976 Grady White "Pacer" at the end of last season. Boat has the 4cyl
Merc. the shift lever seems to be frozen. The engine starts but when I attempt to engage the prop the shift lever is very stiff and the engine cuts out when I move the shifter. Any way to correct this problem ? This is my 1st boat and I'm a novice to boating. Any help would be appreciated.
Re: Frozen Shift Cable
Ayuh,... Replace the offending cable,...
Probably the Lower shift cable...
Disconnect 'em at the shift plate to see which is the problem...
Btw,... Welcome Aboard, 'n please read the forum Rules...;)
Joe Dillon
Thanks for the quick response, Didn't expect one so soon. If i disconnmect the shift cable at the shift plate which I assume is by the transom will it throw anything out of alignment? Also is there a way to unfreeze the cable by greasing it and trying to move it or would this do any damage? While I'm feeling like an idiot I have another dumb question, the steering is stiff also but I don't know if this is because there is no power steering or just the way it should be. It reminds me of steering a car with no powere steering and trying to get out of a parking space. And yes I'm old. And I will read the rules .
