blackrider
- Jun 15, 2011
- 57
Hello,
My name is Jared and I am from Cincinnati. I am new to boats but am a mechanic so I have the mechaical skills to work on my own stuff but am just unfamiliar with certain operations of boats mechanisms. After reading some of the posts on this board I am more than confident that someone can help me out. You guys all seem very good at what you do.
I have a Mercarb ( P/N 1389-9562 ) off of a 1989 Mercury Marine Engine (model MCM 3.0 litre ), displacement is 181, rated HP is 130HP. The thing was running terribly so I put new plugs, wires, points, condenser, rotor and rotor cap at it. I set the point gap at .022 on the peak of the rotor. After all of that it would at least idle without shutting down but it was iding very rough.
I just rebuilt the carb by following the manufacturers instructions. It is totally reassembled now and the linkages are back in place but I am a bit confused about the choke settings. Isn't the choke plate supposted to be wide open unless the electric choke engages it to close?
The way I set it up following the instructions has it mostly closed.
I can post pictures and video of the linkage in action if that will help.
Thanks in advance.
Thanks in advance.
