Re: 5.0 OMC 92 Alternator issue?
Tommays has a Good thought, I have something that Might even be cheaper and shows a LOW Draw. This will work with any 12Volt system that you want to Test a DRAW on. Be careful though checking Automtoive ( newer cars ) with this method as the Draw might be false to to alarms, Radios, and Computer Hot systems need a memory.<br /><br />Take a 12Volt Test Light OR any 12V Automotive Small bulb ( like a Brake light bulb or something Equilv. ) Solder 2 wires on the Bulb. With the test light or bulb ..Disconnect the Battery at either post. Put one wire from the Post and the other to the Cable end you took off. If the Light shines Bright, You have a Draw ! If the Bulb is Off..No draw. I caution you that any LITTLE Draw will make the Light go on...Specially a Low amp Bulb.<br /><br />This will tell you if you have that draw !
