Having a terrible time replaceing my bellows. Clymer Shop Manual says to "push bell housing ... so that the bellows will slide onto the gimbal housing flange." The Seloc Repair Manual says the same. It won't "slide" over with all that I do and I see no way to force it even when the BH is pushed forward of the hinge pin holes. Finally, when I finger-feel that the bellows is maybe over the flange, how do I know when the bellows ridge is in the recess groves on the gimbal flange?? One problem may be terminology: the adhesive tube says to "allow the adhesive to dry until it is tacky" but the shop manual say to "let the adhesive dry ... until it is not tacky." Have tried it both ways with ultra clean flange and bellows. I figure the manual is right because the Quicksilver Bellows Adhesive becomes tacky in about ten seconds after putting it on. In both trys, the bellows broke lose from the flange the next day when I moved the BH in its full range. I'm thinking I may have filled the flange groves so that the buffer ridge never got into the groves. Also it is not clear in the manual if both surfaces, BH and GR, on both flages (BH and GR) should get adhesive. Three days shot. Any help on this problem would be most appreciated.
Many thanks,
Bruce
831 484-9006 (if anyone wants to follow up with a call)
Many thanks,
Bruce
