Fordiesel69
- Sep 18, 2009
- 1,146
1974 Sea ray SRV190
Merc 120HP GM 4cyl
We can run this thing for hours at 3700RPM and it runs excellent. However if we slow down to idle (slow no wake) for 5-10 minutes it will not rev up back up to get on plane. It bogs down and kind of flutters up an down. It did backfire a few times as well. Pumping the throttle a little keeps it running at least. When acting up, it will still run nice at low rpms.
Distributor advance looks good, points look good, fuel filter cut open and looked good with just a tiny bit of dirt on the bottom, and the carb looks spotless inside with no water. We pumped the fuel tank out and found no debris or water.
Any ideas?
-New points in 2009
-New aftermarket manifold in May 2010
-New filter in April 2011
Merc 120HP GM 4cyl
Any ideas?
-New points in 2009
