LilRedNeckGirl
- Jan 25, 2010
- 184
well to an earlier post, we had twins each bogging on a hole shot start. it was suggested that accelerator pumps, or power valve issues might be the blame.
The mechanic again rebuilt the carbs, still no satisfaction, still bogged.
He called mercruiser, and spoke directly to the carb specialists.
The mechanics there say the following.
"Todays gas is nothing like the gas used back in the day, (1985) . the extra gas pumped in on a hole shot isnt enough in many cases, to get the boost needed with the extra load on the engines, so they bog & stall. The jets are too small to allow that gas to work effectively, and take too long to inject it into the carb intake."
The remedy, bore out the two ports where the accelerator pump shoots the gas into the carb venturi. They recommended a 1/16th opening. On dyno tests, it preforms perfect. water test is next weekend , weather permitting.
Again , this issue was on a 1985 wellcraft 24.8 sportsman, with twin mercruiser 3.0 140 hp I/O drives. Carbs are stock.
