rhillman75
- Jul 28, 2010
- 176
I have a 1996 Sylvan 196 with a Mercruiser 4.3 LX Gen+. I went to change all of the fluids today and I notived that the trim pump resevoir had "creamy milkshake that appears to be oil." I used my Mighty Vac to suck everything out, then the manual stated to use ATF!?! I went ahead and filled it with ATF to the right level... but now it seems to be "leaking." Please tell me I did not screw up a seal by using the wrong stuff. I did take both lines of to remove all the fluid and I had a foam cushing under the transom when it slowly came to the ground to rest. The pump still works, I just can't figure out why it is leaking. Both lines are tight and thats where I had suspected the leak but I was wrong.
