Re: mercury 3.0 elbow raiser
Yes salt, 170 degrees when runnig seems to flow well, can i clean it and reuse it? thanks
Ayuh,... The Most Important cleaning you need to worry about at this point is the Gasket Surfaces....
In that picture above, it appears water may have started to leak through into the exhaust...
I see 2 spots that look suspect....
They need to be cleaned Shiney Metal Clean, 'n
FLAT.....
Mount the piece(manifold, or riser) in a vise, or otherwise Secure,...
Then carefully clean the gasket surface with a Flat File....
Don't take off anymore metal than you have too, 'n keep the surfaces Flat, 'n True....
Good Luck....
Oh,... Use Mercruiser factory gaskets,...
They're a Million times better than the aftermarket gaskets I've found...
