Re: 1988 OMC alternator
Rusty, welcome to iboats! Before sending your money to the ebay seller (without a warranty) try contacting a nearby shop that specializes in this type of repair. Many places offer rebuild services which, in my opinion, is far better money spent because you will get YOUR alternator back with the correct parts replaced for a fraction of a new one. On my Delco, I had the bearings and brushes replaced, commutator cleaned, pulley polished and bench tested for under $50. At the very least, have it tested to see what part is actually the problem, then proceed from there. It may be very simple and cheap to effectively repair, as it was in my case. Cheers!
