longstand
- May 2, 2009
- 293
First off, this for a boat. but since everyone here is really smart, i just wanted to give it a try.
The engine is a GM:
Problem:
The Shifter which connects to the carburetor is working properly.
BUT
Instead of using Wire to open the Throttle body to give gas to the engine,
is there a device (ANY Device) i could use to make it electrical.
I want a smooth throttle response and very responsive, its very critical when your docking your boat to have good control of your throttle, you give to much gas it will crash into another boat.
I was thinking of remote control actuator, the same device REMOTE control Car use to turn the wheel.
This is Call RC. Servos:
i was thinking of removing the cable which connect to the Shifter and Replace it with a Servos
what do you guys think. i will do this before summer. anyone had than something like this before?
and of-course its not going to be remote control. I'm going to directly connect the wire to the servos just in-case some other remote frequencies.
The engine is a GM:
Problem:
BUT
