brent.meeker
- Sep 5, 2009
- 3
I have a Merc Alpha One outdrive not sure if it is gen 1 or 2. I have a leak outside on the trim line running to the lift cylinder. I want to replace both of them, but I am not sure what lines to buy. I found p/n 32-99904Q which appears correct. But two different listing for this p/n, one seller says you need two and fits everything (alpha gen 1 & 2, bravo....and more) the other seller says its for the up pressure line only and does not fit alpha 1 gen 1. What lines do I need? P/N's would be great.
Thanks
Thanks
