I have an '86 Mercruiser 170 mounted in an 1986 Sea Sprite 195. The side-mount control is quite loose, and it gives me problems with shift and things.
It's hard to explain, but the arm is loose (as in it wobbles about 1/2"-1" forward and back) but we've tightened that up and it still has play. It's like cables are loose, stretched, not tightened, etc.
Is this common and is it easy to get these tightened? It's nearly impossible to put the boat in neutral and I've rammed the boat quite hard into docks because getting from forward, to neutral, or from reverse to neutral is a PITA.
Example: I get a little forward movement to head up to a dock, then I fight with it to get it in neutral. I do get it in neutral, so we're drifting, so I go to put it in reverse just a tad for a little braking, and it's a fight to get it in reverse gear, so when it does, it throttles up real high, making us back out of the dock.
It seems like I have to move the arm really far forward or backward to get it in and out of gears. Can I tighten these up like the brakes on a bicycle? Can someone explain how to? Thanks!!!!!!
