Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
Alpha 1 Gen 2 Prop shaft straightening?
  • Alpha 1 Gen 2 Prop shaft straightening?
    Hello.I have heard that the A1/G2 prop shaft is made from 2 different metals that are friction welded together to make up the shaft. Does anyone know if this is correct?Also, what is the prefered way to correct a slightly out of spec shaft using heat or just using a shaft?Any information or comments are apprectiated!!Thanks!Pete
    Re: Alpha 1 Gen 2 Prop shaft straightening?
    pete, it is a 2 piece shaft that is friction welded together.have always been told not to straighten because bending back weakens the shaft even more.although i know some people do attempt to straighten them.
    • #3
      Replacement....
      • #4
        Pete, sure you can straighten them... but if you bend a shaft and straighten it then you have weakened it. If youve got a $500. sst prop I wouldnt risk it on a $300.00 propshaft
        Back to Top
