Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Is it important to fog the cylinders during winterization?
  • Is it important to fog the cylinders during winterization?
    Looking to do my own winterization this year, and my shop tells me that one of the things they do is fog the cylinders. Just wondering how important or necessary that is? I've always seen the step of fogging the carb, but don't usually see fogging cylinders as part of the winterization process. It's for a 2005 Volvo 5.0GL. Thanks
    sigpic
    2005 Glastron GX205
    -Volvo Penta 5.0 GL
    2004 Yamaha XLT 800 Waverunner
    Re: Is it important to fog the cylinders during winterization?
    I'm sure you'll get both opinions.
    My manual says fog it. I'm pretty sure the dealer didn't do it last year.
    I did my winterization myself this year and saved hundreds. I simply put mix fuel in the fuel filter and ran it for 5 minutes. Mine is fuel injected.
    Cheers.
    Winter sucks.
    • #3
      It's just as easy to spray some wd-40 in each cylinder through the spark plug hole if you want to "fog" the cylinders. The idea is just to leave a coat of oil/lubricant on the cylinder wall to prevent corrosion and serve as a lubricant for first start-up next year. It's a good idea to do it, but it definitely isn't likely to ruin anything if you don't.
      1976 Mark Twain 200VBR w/Mercruiser 233 (Ford 351w) "Heart & Soul"
      • #4
        I wouldn't use WD-40 as it really isn't a fogging/coating oil. If you are going to spray something use fogging oil.
        Also, when fogging the engine when running is coating much more than just the cylinder walls.
        Winter sucks.
        • #5
          If you fog through the carb, the cylinders and pistons get a light coating along with valves and some other surfaces that don't by just by doing the cylinder through spark plug hole. I use WD40 on the outside of the engine.
          • #6
            if storing for all the winter i would recommend fogging and 1 can will probably last u 5 years!!
            • #7
              Well I just did my first winterizing this year, and it was fairly easy, my local ******* had just about everything I needed, from the outdrive oil fill pump, fogging spray, engine oil, outdrive oil, etc. Anyways, I didnt do the antifreeze method, but did drain all the water out of the engine, and fogged it. I think for $7 for fogging spray its worth doing it.
              • #8
                Here is what Mercury Marine recommends for their new EFI/MPI engines.
                http://www.boatfix.com/merc/Bullet/01/01_15.pdf
                Nobody fogs these engines through the throttle body, like carbs...
                They also don't use the fogging oil in the cylinders through the spark plug ports....
                Rinker 342 FV 2005
                Twin Volvo Penta 5.7 OSXi-DF/OceanX(DPS-B)
                "All things are ready if our minds be so." -Henry V
                • #9
                  That bulletin is 9 years old. Wonder if there is a newer one.
                  I know that Volvo, in their newest operators manual, says only to fog Carb engines and not EFI. Probably due to the Cat Convertors and O2 sensors.
                  1998 Wellcraft Eclipse 24 Cuddy
                  Volvo Penta Duo-Prop 7.4L "LK"
                  2006 Sun Tracker Party Barge 21
                  Mercury 90 4-Stroke FI
                  "Common sense is not very common"
                  "Failing to prepare is preparing to fail." -- John Wooden
                  • #10
                    It also depends on if you are going to leave the boat sitting in the water at the marina, on a trailer out in the weather in a VERY humid place or in your garage.
                    I keep my boat in a dry garage and have never "fogged" it. My last boat went 39 years without being fogged.
                    regards,
                    Rick
                    1987 FourWinns 211 Liberator, Originally OMC 460 King Cobra.
                    Re-powered in 2006 with a 1997 Mercruiser 7.4L Bravo III
                    • #11
                      i think the main thing if you don't fog make sure you keep the moisture from entering points of entry to cylinders
