Re: Need advice on 77' Skipjack 20.5
If the OMC outdrive is an electric shift, I would advise against it. According to my local outdrive mechanic, parts for the next generation cable shift outdrive, are still readily available. <br /><br />I have had a heavily used 800 series cable shift outdrive on my 1975 boat since 1980. It too uses the 'balldrive gear' and it shows no appreciable wear. Neither have I had to have any repair done to it except one impeller replacement.<br /><br />Personally, I like em. They have a much tighter turning radius than the Mercs, the outdrive comes up in a flash and it comes up far enought that you can change your prop while sitting on the transom of the boat.
