mattyrich
- Dec 27, 2008
- 112
Hello there. maybe someone has conquered this problem before.
trying to drop an older 1981 mercruiser 3.0 into a 1991 bayliner whick previously had a 1991 mercruiser 3.0. I am aware of all of the other compatability issues, but this is the last obstacle that im facing.
Both motors have a 12 3/4" flywheel. older motor has the coupler that bolts to studs on the crankshaft and in turn holds the flywheel on.
newer coupler that i need to get on there to match up with the alpha one yoke (drive shaft) bolts to the outer edge of the flywheel.
The only real problem that i have getting the new style coupler to fit is that the studs from the crankshaft, coming through the flywheel come out about 1/4" inch too far for the new coupler to fit flush on the flywheel like it needs to to have clearance from the flywheel housing...
I am wondering if i can make a spacer plate that looks like the base of the older style coupler to hold the flywheel on, then cut about a quarter inch off of the studs so that they will not interfere with the back of the newer triangle style coupler. That way I could use the newer style flywheel housing with the correct mounts to match up with my gimbal.
Ive seen a bunch of different styles of aftermarket couplers on line but im not sure if any of them will work. Anybody solved this problem in the past?
My under standing is that the older style coupler will stick out too far from the flywheel so that the drive shaft from the outdrive wont be able to go in far enough because the splines are not long enough. Could I replace the yolk? What do you guys think I should do??? Thanks, Matt
