Re: How much antifreeze??
Cobra 3.0 rust is a problem, if your manifolds, water jackets, passages, risers are going to sit empty all winter then there is going to be rust. When I winterize my engines I drain them into the bilge and I pump,sponge and wipe up all the water. Then I fill the blocks,hoses with green antifreeze for 2 reasons, any water left in there will mix with the antifreeze plus I get corrosion protection over the winter. In the spring I drain them again into the bilge and I capture all the antifreeze and have actually reused it the next year or dispose of it at the proper facility. A lot of people winterize differently, but mine has worked for me here in Canada for several years with no problems.
