victoryinerie
- Jun 13, 2010
- 62
After replacing the thermostat, sender and several tests on the temperature guage I am convinced my engine is running very cold. I have run the boat in the water and with the muffs and I am getting similar results. The engine is running around 100 and than ocassionaly it will go up to 170 for a second and than it drops right back down to the 100 degree range.
The engine is a 1998 2 barrel, 5.7 Merc. Any suggestins where to go from here? The engine really seems to run fine, how bad is it too run cold like this? At the place I go for parts they thought that the riser should have a restriction gasket and if some one replaced it with the wrong gasket all four slots will be pushing water through. He thought this could be my issue.
It sounds like this could go places where I have not gone on my engine, is there manual I can pull to see what all this should look like if I decide to pull it apart. It appears to be four bolts on the top??
Any thoughts??
Any thoughts??
