Hello All......
I have a 1999 Mercruiser 5.7L EFI Shortblock 350 and here is my problem....
The boat starts up right away with no problems and it idles great! From idle thru full throttle the engine is bogging down and will not go over 2k RPM's while its in the water..... The crazy thing is, while its out of the water with the water muffs hooked up, it revs up to 6k RPM's with no problem whatsoever..... I have replaced the fuel pump, fuel pressure regulator and fuel cooler and fuel filter. I have also replaced the spark plugs and coil. I also had the compression checked out and all cylinders are right around 160 which I was told was excellent..... The boat was sitting for 3 years when I purchased it..... I also replaced the Manifolds and Risers as well as the starter and alternator.... What am I doing wrong?!?.....I really think it has to do with the fuel system!!! I have not checked the timing.... Could the timing cause the engine to bog after 2k RPM's??? I also checked the throttle cable and it looks good!!! PLEASE HELP!!! THANK YOU!!!!
