Hey guys, got a 1997 Mercruiser 5.7 carb Alpha Gen 2 sterndrive.
Its come to a point where i cant kick her over any more. Its not the batteries and i already tried replacing the starter. Checked the dipper for signs of milkyness, nothing.
Removed one bank of spark plugs, all fine.
Removed other bank of sparkys and found the two centre spark plugs showed rust. Outer two were fine.
So then i was thinking it was either the risers cracked or heads cracked.
removed the riser to find the gasket a little damaged, and found puddles of water in the centre of the manifolds where the two rusted spark plugs were.
Could this be the problem?
Riser gasket?
Riser gasket?
