Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Outdrive Leaking Water into Boat
  • Outdrive Leaking Water into Boat
    Hello All
    I'm a new member of this site and could really use some help. I have a 1986 Four Winns with the Volvo Penta outdrive. I had it out this weekend and noticed the boat was taking on water inside the engine compartment. The water is coming in at the top of the outdrive portion. I'm assuming it's a bad seal. Is this something that I could fix myself (Fairly mechanical), or is it best to take it to the shop.
    Thanks in advance!
    Re: Outdrive Leaking Water into Boat
    It's the bellows. That's what you need to search on. Using that term will get more hits or attention.
    I say you need to replace all bellows and check the mechanicals for corrosion while you're at it.
    Searching should yield some results.
    Southern, NJ, USA
    Currently Boatless
    Date an I/O, but marry an outboard!©
    • #3
      Thanks!
      • #4
        I vote bellows as well... Can you do it? Absolutely! Pretty common repair. A flex extension sure makes it easier..
        sigpic
        87 Four Winns 170 Horizon 4.3 OMC COBRA"Only Child"
        only thing GM I own.. Of course it's the only one that gives trouble..
        2004 Ford STX 4x4.
        2011 Candy Apple Ford Mustang GT
        Hope all you want.. It won't get it fixed..
        • #5
          Awesome. Thanks for the help. Mine is actually on an 86 Four Winns. Great Boats!!
          How much time should I expect (then I'll times that by 2)....
          • #6
            bearlaker,
            Philster may very well be right but run some tests before you go yanking the drive off. Put muffs on it in the driveway first and eliminate the water inlet hose. You're sure it's not a transom seal leaking? Like I said, Philster is probably right on the drive bellows. If you do pull the drive, be sure to check the gimbal bearing while it's out.
            • #7
              Will do!! Thanks a lot for the suggestion!
              • #8
                I had the same problem w/ mine but it wasnt the bellow. The pin worked out from my hydraulic ram for my trim and tilt. Looking from the front of the motor, Left side down where the outdrive hooks to the engine. Was enough water to make me very uncomfortable. Just a thought for you.
                • #9
                  If water is coming in through the bellows, and making its way into the bilge,you've got much more repair work ahead of you. What model outdrive do you have?
                  '88 Baretta Success 200
                  Volvo Penta AQ260/275
                  '96 Weeres Suntanner 24
                  '01 90hp Johnson
                  • #10
                    Not what I wanted to hear. Outdrive is an Alpha One. Leaking just started this past weekend (not sure if that makes a difference).
                    • #11
                      You said it was a Volvo in your first post?
                      '01 90hp Johnson
                      • #12
                        Sorry, my bad. It's an Alpha One.
                        • #13
                          good luck
                          • #14
                            They're NOT "QUICK" to say what is leaking but offering suggestions, AND experiences which I APPRECIATE!!!!
                            You need to chill out!
