Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Mercruiser won't go into forward gear!
  • Mercruiser won't go into forward gear!
    I have a 1985 Celebrity with a 350 engine and an Alpha one outdrive. I just replaced the transom and put it all back together. Today i started it up and was checking it out and the drive would not go into forward gear only reverse. I removed the shift control and manually moved the cable but only if i really pushed hard into the housing would it go into forward gear and it was making a clunking sound as if it was not in full forward gear. Not sure what the next step is and summer is running away from us here in Nebraska.
    Any help would be greatly appreciated.
    Re: Mercruiser won't go into forward gear!
    1st the proper criteria.
    fwd= prop locks ccw and ratchets cw
    neu= prop freewheels either direction w/o sound or feel
    rev= prop locks cw and ratchets ccw
    if you've removed the lower shift cable from the shift plate inside the boat you should be able to meet the above criteria by just moving the shift cable in and out. it should move very freely.
    if it don't i think my next step would be to be sure the cable got routed proper. proper routeing will be found in the mercrusier s/m applicable to your rig. if that's ok, i'd think next step would be to remove the drive and again, see if the cable moves very freely. if not. time to R&R the cable. and '85 could easy need replacement if it's never been before..
    i hear ya on our times getting short. a month, maybe 2 on the outside and we'll be winterizing..
    'Lime Time'
    1975 AristoCraft Nineteen
    Mercruiser 165hp (chevy 250 L6), MC-1 drive
    • #3
      Actually, before you check any of that, make sure that you assembled the drive to the transom with the shift shaft connected properly. Sometimes when people have this problem it's because the transom shaft is not in or not seated in the drive end. Did you install the drive with the shift lever in forward?
      If it's not that, then probably your shift cable (upper or lower) needs adjustment. There's tips on doing that here, mostly in posts where people have had to replace the lower shift cable.
      Erik
      Sea Ray SRV-210 - Winter refit
      75-85 foot displacement hull trawler - gleam in my eye
      • #4
        I checked to make sure the that the shift shaft is moving correctly and it is. I unhooked the cable from the contol and manually moved the shift shaft and it locks like it should in forward and reverse gear. I measured the lower shift cable and it measures 6" like it should. I climbed out of the boat with boat in forward gear and shift shaft was in correct position. When in neutral the prop spun free. When in full reverse shift shaft moved correctly. What should i do next?
        • #5
          There is a shift cable adjustment procedure here: http://www.perfprotech.com/store/app...ift-adjust.pdf Starts on page 86. Good luck.
          Terry
          87, 4WINNS H 190
          470/Alpha I
