Spivy30
- Jul 19, 2008
- 299
I just bought a 1968 Starcraft Holiday with a 120 mercruiser. I havent had the boat out on the water but when I try to start it on the hose the starters stays enguaged most of the time. I checked the ignition switch and swapped it out with a different one and northing changed. It wont start in gear but if it wont stop cranking and I put it in gear it doesnt stop. The only way to get it to stop cranking is to disconnect the battery. Usually when I try and reconnect the battery it starts cranking again. The previous owner out a new starting solenoid in it a few days before I bought it. Is it possible that the new soleniod is sticking I can hear it clicking. Im affraid to do anything thing with the boat because I dont want to burn out the starter. Does the new solenoid need to be greased or anything?
