Hello all, this is my first time posting so pardon me if this topic has been covered before. I own a 99 Campion 525 with a Mercruiser 3.0 I/O. My first year owning I hired the wrong guy to winterize my boat. He broke off the blue plastic plug to drain the block. Don't worry he says I had a steel bolt that fits. It fits but it leaks about a quart an hour. It is also a 1/2 in. fine screw where the original brass fitting was 1/2 in. coarse. What do members think? Should I just get a coarse thread 1/2 in steel bolt and carefully try to rethread the brass fitting by screwing it into the hole? Or should I try to find a tap set that would match it. If so would a tapered tap be best? The blue replacement plug only needs about 4 threads for its depth.
Thanks for any help.
