Re: DUO PROP vs. SINGLE SX ON A V-PENTA 5.0 GXI (270HP)
I have that same boat with a 5.0 SX 220. The 220 is the smallest engine I would put in that boat. It is fine for slalom skiing with a light load of 3 or so people in the boat. It does get a little sluggish out of the hole with 4 adults and 3 small children in it, but is still fine for wakeboarding and 2 ski skiers. I have included a fast facts about the 194 that I got from Four Winns, it may help your decision. One thing I have found is that the 5.0 (carbed or FI), pulls harder out of the hole if it is propped to let it get a bit over 3000 rpm during acceleration. Propping to load the motor too much out of the hole hurts acceleration. The fast facts shows the SX models pulling a 21in. prop. My boat was delivered with a 19 and I run a Volvo 19 SS. With just me in the boat, but full fuel and water, I get right at 48-49 mph at 4800rpm, so I think I am propped right. You will also notice from the charts that the main difference between the SX and the DP is that the DP appears to be planed off at 2500rm, while the SX does not. In reality, the SX 220 in my boat will plane at 2600rpm. Overall, I am pleased with the package. Anyway, here is the fast facts I have for it. Hope this helps...<br /><br />194 FUNSHIP<br /><br />Specifications US METRIC<br />LOA: 213 6.40 m<br />Storage Length: 2111 6.68 m<br />Beam: 8'6" 2.59 m<br />Keel to W/S Shelf: 49 1.45 m<br />Total Height: 5'11" 1.80 m<br />Total Height on Trailer: 7'4" 2.24 m<br />Transom Angle: 13˚ 13˚<br />Deadrise: 17˚ 17˚<br />Bridge Clearance: 4'9" 1.45 m<br />Cockpit Height (stern): 29" 74 cm<br />Cockpit Height (helm): 35" 89 cm<br />Freeboard (min.): 32" 81 cm<br />Draft (drive down): 31" 79 cm<br />Draft (drive up): 14" 36 cm<br />Fuel: 50 gal. 189 l<br />Persons Capacity: 11 11<br />Maximum Capacity: 1700 lbs 771 kg <br /><br />Power Ratings & Weights <br />Engine Propshaft Power Boat & Engine Weights<br />Type HP KW Lbs KG<br /><br />MC4.3L/A 190 142 3700 1680<br />VP 4.3GL/SX 190 142 3750 1700<br />MC4.3MPI/A 220 164 3730 1690<br />VP 4.3GXi/SX 225 169 3780 1710<br />VP 4.3GXi/DP 225 169 3800 1720<br />MC5.0L/A 220 164 3800 1720<br />VP 5.0GL/SX 220 164 3850 1750<br />MC5.0MPI/A 260 194 3810 1730<br />MC5.0MPI/B1 260 194 3900 1770<br />VP5.0GXi/SX 270 201 3860 1750<br />VP5.0GXi/DP 270 201 3880 1760<br /><br />Recommended Engine(s)/Equipment Avg. Weights<br />Model Eng. Type Boat Eng. Battery Fuel Access. Trailer Wt. <br />LBS<br />194FS VP 5.0GL/SX 2790 1000 60 300 150 1160<br />KG<br />194FS VP 5.0GL/SX 1265 454 27 136 68 526<br /><br />Performance<br />Power HP/ KW Propeller (Dia x Pitch) Type Top Speed Cruise Range<br /> IN CM MPH KPH MI KM<br />MC4.3L/A/190/142 141/4 x 21 36 x 53 AL 44-47 71-76 160 258<br />VP4.3GL/SX/190/142 141/4 x 21 36 x 53 AL 43-46 69-74 160 258<br />MC4.3MPI/A220/164 141/4 x 21 36 x 53 AL 46-49 74-79 160 258<br />VP4.3GXi/SX/225/169 141/4 x 21 36 x 53 AL 46-49 74-79 160 258<br />VP4.3GXi/DP/225/169 F7 F7 SST 47-50 76-81 170 273<br />MC5.0L/A/220/164 141/4 x 21 36 x 53 AL 46-49 69-79 150 242<br />VP5.0GL/SX/220/164 141/4 x 21 36 x 53 AL 45-48 72-77 150 242<br />VP5.0GL/DP/220/164 F6 F6 SST 46-49 69-79 160 273<br />MC5.0MPI/A/260/194 141/4 x 21 36 x 53 AL 48-51 77-82 160 273<br />MC5.0MPI/B1/260/194 143/4 x 21 38 x 53 SST 48-51 77-82 160 258<br />VP5.0GXi/SX/270/201 141/4 x 21 36 x 53 AL 47-50 76-81 160 258<br />VP5.0GXi/DP/270/201 F6 F6 SST 48-51 77-82 170 273<br /><br />Fuel Flow Data - 194 FUNSHIP with VP4.3GL/SX/190/142& MC4.3L/A/190/142<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 12 19 5 19<br />3000 26 42 7 26<br />3500 32 52 10 38<br />4000 39 63 13 49<br />4500 44 71 16 60<br />WOT 46 74 18 68<br /><br />Fuel Flow Data - 194 FUNSHIP with VP4.3GXi/SX/225/169& MC4.3MPI/A/220/164<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 12 19 5 19<br />3000 26 42 7 26<br />3500 33 53 10 38<br />4000 40 64 13 49<br />4500 45 72 17 64<br />WOT 48 77 19 72<br /><br />Fuel Flow Data - 194 Funship with VP4.3GXi/DP/225/169<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 8 13 4 15<br />2500 18 29 5 19<br />3000 27 43 7 26<br />3500 35 56 11 42<br />4000 42 68 14 53<br />4500 46 74 17 64<br />WOT 49 77 19 72<br /><br />Fuel Flow Data - 194 FUNSHIP with VP5.0GL/SX/220/164& MC5.0L/A/220/164<br />Engine Speed - RPM Boat Speed Fuel Flow<br />MPH KPH GPH LPH<br />2000 8 13 5 19<br />2500 13 21 6 23<br />3000 27 43 8 30<br />3500 34 55 12 45<br />4000 42 68 15 57<br />4500 46 74 17 64<br />WOT 47 76 19 72<br /><br />Fuel Flow Data - 194 Funship with VP5.0GXi/SX/270/201 & MC5.0MPI/A/B1260/194<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 9 14 5 19<br />2500 18 29 7 26<br />3000 28 45 9 34<br />3500 36 58 12 45<br />4000 43 69 15 57<br />4500 48 77 19 72<br />WOT 50 81 21 79<br /><br />Fuel Flow Data - 194 Funship with VP5.0GXi/DP/270/201<br />Engine Speed - RPM Boat Speed Fuel Flow<br /> MPH KPH GPH LPH<br />2000 9 14 5 19<br />2500 19 31 7 26<br />3000 29 47 9 34<br />3500 38 61 12 45<br />4000 44 71 15 57<br />4500 48 77 19 72<br />WOT 50 81 21 79<br /><br />Performance and Fuel Flows may vary widely due to Boat Weight, Load, Atmospheric Conditions, Engine Conditions, Weight Distribution, Sea Conditions, Propeller, Boat Bottom Condition, Trim Angle and Operator Technique.
